Spotted Dog 0 Posted August 10, 2021 Hi! I just bought a Graphtec CE7000-60, I use Oracle Oramask 813 stencil paper. When I try to print a longer stencil (48") the stencil paper slides out of place and often causes a jam. I have tried to re-place the rollers. It will print smaller stencils without any trouble. Any help is most appreciated! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 10, 2021 the ce7000 won't print - only cut - if using as a cutter I would guess one of 2 things - too much blade exposure causing drag or the known issue of the vinyl bunching up between the rollers as it feeds. feed it without cutting or using a pen and see if the vinyl raises up between the rollers or stays flat Share this post Link to post Share on other sites
