JennDupe
Print/Cut Software
I purchased a PrismCut to replace my Graphtec CE6000 that is 10 years old and has become extremely finicky with contour cutting. All of my files are set up in illustrator with Cutting Master 4, is there a software I can use with PrismCut that mimicks Cutting Master? I've tried working with VinylMaster this evening, and it doesn't seem to be very user-friendly for the type of work I do. On Illustrator, I can have my print layer and registration mark layer switched on for printing, then turn it off and turn on my cut layers for cutting. Vinyl Master doesn't seem to have that option even when I import the objects separately, it doesn't seem to recognize the "print" object and the "cut" object unless I am missing something?
I will attach an example of the print/cut files below
