JohnnyPop 0 Posted July 5, 2021 Hi all and thanks in advance. Sooooooo Flexi stopped cutting. Not had an issue in who knows how many years and then Flexi stops cutting. In Production Manager it sends it to cut, the cutting bar cycles through 100% but nothing comes out the cutter (US CT30). My baud is set the same on the cutter and the settings, Flexi is set to cut now. I've tried everything I can think of. I'm out of ideas. Flexi 10.5 on Windows 10. Can any of you guru's help ??????? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 5, 2021 No mention of which version of Flexi on which computer operating system. Share this post Link to post Share on other sites
JohnnyPop 0 Posted July 5, 2021 7 minutes ago, MZ SKEETER said: No mention of which version of Flexi on which computer operating system. Flexi 10.5 on windows 10 Home (I've edited post) Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 5, 2021 1 minute ago, JohnnyPop said: Flexi 10.5 on windows 10 Home (I've edited post) Does it have a USB dongle ? Example shown Share this post Link to post Share on other sites
JohnnyPop 0 Posted July 5, 2021 20 minutes ago, MZ SKEETER said: Does it have a USB dongle ? Example shown Yeah it does. All seems fine with it and the USB port. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 5, 2021 Check your settings in your computer, check your cables. reinstall the USB driver for cutter cable if connected USB. If using USB, make sure com port numbers are matching in computer as well as software. Must be between 1-4, nothing higher. Also, Windows 10 may have done an update and changed things. Reinstall the software and drivers and set up again. Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 5, 2021 It may seem trivial, but every once in a while I have had to clean out the contacts in USB thumbnail drives. Yep, just pucker up and blow into the thing. Share this post Link to post Share on other sites
