andres hulais 0 Posted June 30, 2021 I m using my uscutter MH-871-MK2 exclusively with a rotring pen to draw plans. The files are sent from the corel draw and many times I experience some errors (which I think are post-processing) such as jerks in the axes (x or Y). Sometimes it does and sometimes it doesn't. What software do you recommend from you to make the prints of the plans and avoid these errors? i have tried on plt ... and various extensioens ....I, I can buy it your software I have no problem. today i buy the original software Vinylcut, but the problem is still... y draw in core archive plt... see it in picture in screen and error in paper :( Share this post Link to post Share on other sites
darcshadow 1,625 Posted June 30, 2021 Have you ran the calibration routine in the software? Share this post Link to post Share on other sites
andres hulais 0 Posted June 30, 2021 Speed 40 press pen 190 is that what you ask me? Another problem is that the letter makes them double, and it is a spelling of a single line Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 30, 2021 10 minutes ago, andres hulais said: Speed 40 press pen 190 is that what you ask me? Another problem is that the letter makes them double, and it is a spelling of a single line File> Vinyl spooler> Calibration>cutter scale Double. try and slide away and see if there are 2 layers of the file. Slide away and delete. Share this post Link to post Share on other sites
andres hulais 0 Posted June 30, 2021 I can't find what it tells me ... there are no double layers ... here should I change or choose a more suitable path? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 30, 2021 That cutter doesn't have a lot of memory. It also has a cheap Chinese chipset. Not TRUE usb like higher end cutters. Some people have no problems with the USB connection. Others nothing but problems. Best to run on a serial connection or a Tripp-lite Keyspan adapter (that is the brand name and known to work with vinyl cutters) and the null modem cable that came with the cutter. 1 Share this post Link to post Share on other sites
darcshadow 1,625 Posted July 1, 2021 While true, I don't believe memory is the issue here. Could be a tracking issue, I don't have much experience with running paper through the cutter so I'm not sure how well it tracks compared to vinyl. How big is this image? Try making a simple image the same size. Say just a large box with a circle in it. How does that come out? 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 2, 2021 I think it's either a tracking issue or some sort of x/y calibration issue. I wouldn't even know how to dial that in on a MH cutter. As to the double cutting/drawing, take a look in outline mode. If you are having this issue with text it is because the cutter/plotter is designed to cut vinyl and the text litterally has an outline rather than being a single line so the cutter is tracing the outside of each letter so it does in fact have two lines. In the case of vinyl work the end result is a letter that is left after removing the excess unused vinyl (weeding) and you see a letter. In your case you get an outline around the edge of the letter as traced with the pen. Your plotter/cutter is capable of just doing a single line but the software you are using may not be capable of producing DRAFT like effects due to it being designed for vinyl cutting rather than plotting out a scaled drawing. Share this post Link to post Share on other sites
