Guest dan scannell Posted April 30, 2021 when i vectorize a line drawing it creates a separate vector on each side of the line . how do I create a vectorized line drawing with just one vector ON the line? So what happens now when I send it to my Titan 2 cutter it cut it out on both vectors on each side of the line. Hope thats clear. Any help would be appreciated. Thanks Quote Share this post Link to post Share on other sites
haumana 1,220 Posted April 30, 2021 Thanks for coming to the US Cutter forum. Just an FYI - if you take a few minutes to register then your posts will go up immediately instead of waiting for a moderator to approve it. If there is weight (line thickness), then the vector engine is doing its job properly. That's pretty much going to happen in most vectorizing programs. Are you willing to post the file? Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 30, 2021 every line has an inside and an outside line, or there were not be anything to stick at all. Vectors are outlines. Maybe show what you are trying to accomplish. Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted May 1, 2021 Can't be done with an auto trace. You'd have to trace it manually, or modify the image being traced to fill it in. Quote Share this post Link to post Share on other sites
