lilone2j 1 Posted March 11, 2021 ok, so sometimes the machine does not cut the middle of an a or the whole a, sometimes the machine skips a bird on a project, sometimes the on in Son does not cut sometimes just the inside of the o. always these same issues in the projects but not always on every project. super random when it will happen and when it won't. I'm using Inkscape to design/add text and then opening in graphtec studio to send to ce7000 for cutting. everything is set as a path in Inkscape Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2021 2 hours ago, lilone2j said: ok, so sometimes the machine does not cut the middle of an a or the whole a, sometimes the machine skips a bird on a project, sometimes the on in Son does not cut sometimes just the inside of the o. always these same issues in the projects but not always on every project. super random when it will happen and when it won't. I'm using Inkscape to design/add text and then opening in graphtec studio to send to ce7000 for cutting. everything is set as a path in Inkscape Make sure you are cutting all colors , sounds like some of the design might not be all the same color and you might be cutting by color Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 11, 2021 Why not design and cut from graphtec studio pro, it’s about a $2000 that comes with the ce7000 Share this post Link to post Share on other sites
lilone2j 1 Posted March 12, 2021 because I only allowed to have it on 1 machine and I design on a different machine than the one connected to my machine unfortunately. Share this post Link to post Share on other sites
lilone2j 1 Posted March 12, 2021 3 hours ago, Dakotagrafx said: Make sure you are cutting all colors , sounds like some of the design might not be all the same color and you might be cutting by color it is all the same color and I have cut 2 of the same project one after the other and had different results with both cuts, same settings Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2021 Weird, I use graphtec studio pro every day and never seen that Share this post Link to post Share on other sites
lilone2j 1 Posted March 12, 2021 yeah, it's crazy. I don't know how I'm supposed to problem solve it when it's not consistent. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2021 call graphtec support = but firsts create the design directly in graphtec studio pro to eliminate the inkscape factor - then call them Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 12, 2021 14 hours ago, lilone2j said: because I only allowed to have it on 1 machine and I design on a different machine than the one connected to my machine unfortunately. I do things on several different computers sometimes. I just save my files to an email draft to myself. I can get my files from any computer, by email drafts. If something happened to one of my computers. My files are easy to access. Share this post Link to post Share on other sites
lilone2j 1 Posted March 13, 2021 20 hours ago, MZ SKEETER said: I do things on several different computers sometimes. I just save my files to an email draft to myself. I can get my files from any computer, by email drafts. If something happened to one of my computers. My files are easy to access. do you use grapthec studio? Share this post Link to post Share on other sites
lilone2j 1 Posted March 18, 2021 On 3/12/2021 at 8:28 AM, Dakotagrafx said: call graphtec support = but firsts create the design directly in graphtec studio pro to eliminate the inkscape factor - then call them So I saw another post where it was recommended to uncheck auto-weld, I did that and everything seems to be cutting now..... 1 Share this post Link to post Share on other sites
