Guest Kevin Posted March 5, 2021 We use the VinylMaster Cut that came with our SC cutter and often cut multiple different designs at once. Is there a way to place our cuts on the work area and then have VinylMaster auto arrange them into place in the best layout to conserve material? We spend a lot of time placing things into position manually and I've worked in a sign shop previously that had software to auto arrange the cuts, but it wasn't VMC. Thanks! Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 5, 2021 Flexi software has Nesting. But it is much more expensive than Vinyl Master Cut. Look in HELP at the top of your layout screen, there are many tutorials. And an index for search words. It may be possible that you would need a higher version of Vinyl Master for that. Sign up as a member, no cost and faster for questions posted. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 7, 2021 Vinyl Master DSR has a nest to page function that appears to do what you are looking for. Not sure what level of VM this feature gets unlocked but the DSR level has it. 1 Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted March 19, 2021 CUT Documents start in PRO. Quote Share this post Link to post Share on other sites
