JOSE GARCIA 0 Posted February 22, 2021 Some time ago, our electrician was doing some job at the warehouse, and he touched something that cause the power to go off / on.. From that day my plotter did not cut anymore. I thought the mother board had died, since it did not start anymore. I tried several times, and suddenly one day it turned on again. I was able to set it to Factory Settings, and run a test in the machine. It worked. But the problem is connecting it to the computer: it does not recognize it. I bought a new USB 2.0 cable, and nothing, even tried in different computers; so, I bought a 32 pin to USB cable, and it didn't work. My guess is the side where the usb is connected to the computer might have received the damage of the electric charge. I am just thinking on throwing it away, unless someone here can provide me with an idea, since I am not an electronic's expert. Please feel free to share if you have experience with this, Thanks, Joe. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 22, 2021 You stated. I bought a 32 pin to USB cable, and it didn't work. What didn't work about it? So you down loaded the driver and installed it? And it didn't show a com port in your computer? Not all USB to serial cables will work with a vinyl cutter. We only recommend a Tripplite Keyspan Adapter or a Belkin. Then add a null modem cable between the Adapter and vinyl cutter. That cutter has a RS-232C connection. I found that on the specs. Are you sure it is 32 pin? Both of my FC units only have a RS232C 25 pin connection. Haumana how many pins are on your Graphtec CE6000 for the RS232C? 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 22, 2021 2 hours ago, JOSE GARCIA said: Some time ago, our electrician was doing some job at the warehouse, and he touched something that cause the power to go off / on.. From that day my plotter did not cut anymore. I thought the mother board had died, since it did not start anymore. I tried several times, and suddenly one day it turned on again. I was able to set it to Factory Settings, and run a test in the machine. It worked. But the problem is connecting it to the computer: it does not recognize it. I bought a new USB 2.0 cable, and nothing, even tried in different computers; so, I bought a 32 pin to USB cable, and it didn't work. My guess is the side where the usb is connected to the computer might have received the damage of the electric charge. I am just thinking on throwing it away, unless someone here can provide me with an idea, since I am not an electronic's expert. Please feel free to share if you have experience with this, Thanks, Joe. Could be a main board that runs around $650. If it comes down to disposing it I might be interested in paying shipping for the plotter and stand to fiddle with it. Share this post Link to post Share on other sites
