Bunky67 0 Posted January 28 My 871 was bought used and I have used it of course but the rubber grit rollers have a build up on them from being used and not cleaned properly... I tried a little rubbing alcohol on a rag and that took off some. But I need to get them better. Can I use goo gone or something similar? Also has anyone found a replacement roller for these without changing the whole roller unit ? Share this post Link to post Share on other sites
haumana 1,037 Posted January 29 Are you talking about the pinch rollers? If so, I do not recommend you use alcohol to clean them, and it can dry it out. I don't know if goo gone would leave a film. If you google, I'm sure you can find replacement pinch rollers, and those get changed from time to time. Share this post Link to post Share on other sites
slice&dice 2,250 Posted January 29 GooGone is easily the best way to go. (Just wipe the oily residue with some warm soapy water to clean it off) Share this post Link to post Share on other sites
