gili 0 Posted January 11, 2021 uddenly the device makes a weak cut at a certain location And also transfers displacement cutting What is the problem? I noticed the rubber is worn, is that the problem? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 11, 2021 The belt looks horrible. Replace it. Clean your pinch rollers. You for sure are picking up vinyl and it is all over your pinch rollers. Look at your teflon cutting strip also for gouges and scratches. Make sure the blade exposed out of your blade holder is correct and not lifting vinyl. 2 Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 11, 2021 The belt is not good, but I don't believe it would cause the cutting problem you are noticing. I'd also be concerned as to how the belt got that way. Once replaced I'd keep an eye on the new belt to make sure something is not rubbing it. 1 Share this post Link to post Share on other sites
gili 0 Posted January 11, 2021 Thank you Can I buy a belt? And how do you install the new one? My machine is old but works a lot, I will give it attention and I will renovate it Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 11, 2021 We don't even know what machine it is. Look up the part number on the belt online. You should be able to find some kind of instructions on youtube. 2 Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 12, 2021 B'vaka'sha. https://www.uscutter.com/Belt-short-for-SC-and-TC-Series-Vinyl-Cutters 1 Share this post Link to post Share on other sites
gili 0 Posted January 14, 2021 I did not find any belt replacement instructions My machine - rabbit I would love if anyone has such a link Thank you Share this post Link to post Share on other sites
