Chris81 0 Posted November 30, 2020 Hello, I have not been able to find a good printable photo magnet that gives good quality and printing. So I am using an adhesive magnet sheet and then a Canon pro luster photo paper glued to that. I am using a Prism Cut machine and trying to cut these magnets, however, no matter what I try I can't seem to get a clean cut. I've tried each degree blade, all sorts of pressures and speeds. But what's happening is it sort of crinkles the paper, I believe because the blade has to get deep enough to cut through the magnet. I have attached a picture of what it looks like. Any suggestions on how I can get a good clean cut? I'm not opposed to buying a new machine, blade, trying other photo paper, etc. Thanks! Share this post Link to post Share on other sites
Wildgoose 4,179 Posted November 30, 2020 Have you tried multiple lighter cuts? Like maybe 3 passes? 2 Share this post Link to post Share on other sites
haumana 1,169 Posted November 30, 2020 Ditto on the multiple cuts 1 Share this post Link to post Share on other sites
Dakotagrafx 7,279 Posted November 30, 2020 my guess would be that adhesive layer is causing you the problem - 1 Share this post Link to post Share on other sites
Wilson-Flyer 0 Posted March 13, 2021 I'd like to re-visit this topic, if I may. I also have a Prismcut 28 and had been wondering about cutting magnetic mat material but had just decided best not try. Now my curiosity is sincerely piqued. Did you ever get this to work successfully? Should our cutter be used to cut this material? If so, please share any knowledge you'd be willing to as to how you accomplished it. Thank you! Share this post Link to post Share on other sites
