tequilajade 1 Posted November 28, 2020 MH871 running on windows 10. vinyl master cut as spooler software, and adobe illustrator to design. this thing is brand new.... I got it on friday (as in YESTERDAY) and the blade doesn't go up and down. It was to replace a chinese brand one that the cutter/computer communication wouldn't work at all. I had a TITAN for years, and never any major issues. right now, if Cricut made one big enough, I'd get it just to get these damn stickers made that are now way beyond overdue. The blade holder doesn't lift and lower. every 4th or 5th time I power off and reset, the blade will move, but it's uncommon. if I manually press it so it's touching the vinyl, when it cuts, it just drags the blade across and doesn't lift it before starting the next cut. I thought maybe it was a software or design issue, so I tried the test cuts, both provided with vinyl Master, and the test button on the machine. Same story. I took the cover off the carriage to try to see if maybe something was blocking it. it has some resistance if I press on it. if it wasn't an electric copper motor coil thing I'd put a drop of lube in there to see what happens. I can't call tech support till monday, and I'll be back at work then. I can only blame vinyl supply chain for not churning out these stickers for so long any ideas? Share this post Link to post Share on other sites
haumana 1,220 Posted November 28, 2020 Sounds like a z-chip issue. Definitely get in touch with customer support. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 28, 2020 Sounds like the solenoid is not centered so it is hitting the coils from your description. Usually we here of carriages off track during shipping but now and then a solenoid is slightly off center and causes the resistance you are feeling if you are testing the motion with the power off Share this post Link to post Share on other sites
tequilajade 1 Posted November 28, 2020 1 hour ago, Dakotagrafx said: Sounds like the solenoid is not centered so it is hitting the coils from your description. Usually we here of carriages off track during shipping but now and then a solenoid is slightly off center and causes the resistance you are feeling if you are testing the motion with the power off thanks, that was the issue I was leaning toward myself. is there anything I can do myself, or is this a tech support issue? thankfully I live about 20 miles from USCutter, so at least shipping and all that isn't an issue just the fact that it's absolutely brand new, and isn't working properly. Share this post Link to post Share on other sites
tequilajade 1 Posted November 28, 2020 PXL_20201128_234255792.mp4 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 29, 2020 They used to have a video showing taking the cover off of the carriage and adjusting it on another model but looks like it is gone now. I had a new 1900 graphtec I had to send back (which is far less common than a Chinese mh) . . , it happens from time to time as the ships carrying the containers get jostled at sea on the way over. Share this post Link to post Share on other sites
tequilajade 1 Posted November 29, 2020 7 minutes ago, Dakotagrafx said: They used to have a video showing taking the cover off of the carriage and adjusting it on another model but looks like it is gone now. I had a new 1900 graphtec I had to send back (which is far less common than a Chinese mh) . . , it happens from time to time as the ships carrying the containers get jostled at sea on the way over. i guess I'm going to have to call them on monday. I don't really want to load this thing into my tiny vehicle, unless I have no other options. 1 Share this post Link to post Share on other sites
Lamar 0 Posted January 25, 2021 On 11/28/2020 at 7:10 PM, tequilajade said: i guess I'm going to have to call them on monday. I don't really want to load this thing into my tiny vehicle, unless I have no other options. were they able to help you with this I'm having the exact same issue Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 25, 2021 9 minutes ago, Lamar said: were they able to help you with this I'm having the exact same issue The OP dropped in on NOV 28th, 2020 and never dropped back again. Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 26, 2021 The problem is most likely the Z-chip got fried and will need to be replaced. The early models of the MH the chip was in a socket and could easily be replaced. Newer models the chip is soldered in, still replaceable, just not as easy. The chip is a simple op-amp and can be found from several online electronic stores. Do a search on here for Z-chip, we just had this discussion about a week ago. You'll find all the details you need. Share this post Link to post Share on other sites
