1clo1 4 Posted November 26, 2020 Thanks i was asking because Slice&dice said they use 30 for intricate designs. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 26, 2020 9 minutes ago, 1clo1 said: Thanks i was asking because Slice&dice said they use 30 for intricate designs. His bold type indicates to me that is something he found on a site, I am only offering 12 years of personal experience as my wife and I have done a lot of fine detail. Slice does have a lot of experience with the mh plotter Share this post Link to post Share on other sites
1clo1 4 Posted November 26, 2020 Thank you, so use the 60 for everything instead of the 45 and it should be fine? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 26, 2020 That has been my experience for years Share this post Link to post Share on other sites
1clo1 4 Posted November 26, 2020 Thanks, should I still set the overcut or leave that if I use the 60 blade? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 26, 2020 test it first - you can try upping the overcut a little if the cuts are not totally closing - it kind of makes up for the course stepper motor in the mh when it doesn't close the ends of the cuts Share this post Link to post Share on other sites
1clo1 4 Posted November 26, 2020 ok thanks, I will switch blades and try to adjust the overcut. do you know if this cutter will cut reflective vinyl? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 26, 2020 it will cut it - just don't try to do anything very small - and reflective will eat blades so have several extras on hand cut slow after you test to make sure your blade exposure and force are right for the reflective - it is tough material Share this post Link to post Share on other sites
1clo1 4 Posted November 26, 2020 1 hour ago, Dakotagrafx said: it will cut it - just don't try to do anything very small - and reflective will eat blades so have several extras on hand cut slow after you test to make sure your blade exposure and force are right for the reflective - it is tough material Ok thanks, So should the 60 blade will work for the reflective, on 10 speed? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 26, 2020 29 minutes ago, 1clo1 said: Ok thanks, So should the 60 blade will work for the reflective, on 10 speed? I have no idea what a 10 speed is on the current version of the mh main board, over the years the different versions a 10 was same as a 60 or something Else as it is an arbitrary number and really has no reference Share this post Link to post Share on other sites
haumana 1,220 Posted November 26, 2020 Ditto on the 60* for everything. I have never gone back to a 45* 1 Share this post Link to post Share on other sites
1clo1 4 Posted November 26, 2020 22 minutes ago, Dakotagrafx said: I have no idea what a 10 speed is on the current version of the mh main board, over the years the different versions a 10 was same as a 60 or something Else as it is an arbitrary number and really has no reference Thanks for the info Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 26, 2020 Just looking at what you showed as your offset and overcut numbers. The 0.25mm offset is likely very close but as mentioned often needs a minor tweak but your overcut of 2 mm is probably more than you need. If you have a decent magnifying glass take a look and see if the start and stop points on a circle stop at about the same place or if they go past each other. Typically the overcut feature is not needed but if your cuts do not start and stop in the same spot you use that to help it. Most times it is somewhere in the same neighborhood as the blade offset. I don't think too much overcut will hurt anything but it may leave little tags of vinyl if the cuts at the start and end do not line up perfectly. If you are trying to determine the perfect blade offset with perfect corners you will want to use a small box (like a half inch or an inch) and cut it and look at the corners, Then change the offset a little and cut again until you can find th sweet spot between rounding off the corners and leaving weird spikes at the corners. Here is a little chart that may help you visualize it. 2 Share this post Link to post Share on other sites
haumana 1,220 Posted November 26, 2020 If you are going to change your blade, regardless of degree/angle, I would highly recommend Clean Cut Blades. They do make a huge difference. 2 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 26, 2020 10 minutes ago, haumana said: If you are going to change your blade, regardless of degree/angle, I would highly recommend Clean Cut Blades. They do make a huge difference. All I use too, but newbie might want to learn on the cheap ones Share this post Link to post Share on other sites
haumana 1,220 Posted November 26, 2020 2 hours ago, Dakotagrafx said: All I use too, but newbie might want to learn on the cheap ones True, but I got to admit - mine survived and is still in the machine, even through my learning days ... 12+ years. I think I need to use my cutter more often. Hahaha. 1 1 Share this post Link to post Share on other sites
carlos alberto bolivar 0 Posted November 28, 2020 necesito instalaren mi pc que tiene windows 10 el ploter de corte ucutter MH871-MK2, pero no tengo el disco de instalación, por favor necesito ayuda con un link y poderlo instala Share this post Link to post Share on other sites
haumana 1,220 Posted November 28, 2020 16 hours ago, carlos alberto bolivar said: necesito instalaren mi pc que tiene windows 10 el ploter de corte ucutter MH871-MK2, pero no tengo el disco de instalación, por favor necesito ayuda con un link y poderlo instala http://www.uscuttersupport.com/downloads.html Share this post Link to post Share on other sites
edison carrasco 0 Posted February 5, 2021 compre un uscutter mh871-mk2 y no me llego el CD para instalar los driver para windows 10 y necesito ayuda para poder instalarlo.. en intentado buscarlo no me aparece los driver Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 5, 2021 43 minutes ago, edison carrasco said: compre un uscutter mh871-mk2 y no me llego el CD para instalar los driver para windows 10 y necesito ayuda para poder instalarlo.. en intentado buscarlo no me aparece los driver https://ftdichip.com/wp-content/uploads/2020/08/AN_396-FTDI-Drivers-Installation-Guide-for-Windows-10.pdf 1 Share this post Link to post Share on other sites
