Stevem9 1 Posted November 16, 2020 Trying to make a vinyl template for a cribbage board and haven't been able to figure out how to make the dot follow the curves, i cant just order one because i need it to fit a certain size, 9.75" x 4.75" looking to do something like this: Share this post Link to post Share on other sites
haumana 985 Posted November 16, 2020 Do you mean that you're trying to rotate the cross hairs? Sorry, I don't play cribbage and haven't seen a real cribbage board in decades. Share this post Link to post Share on other sites
Stevem9 1 Posted November 16, 2020 Me either, lol. my girlfriend is making Christmas gifts for some family members. All Im looking for is the dots, the lines are easy because I just use the duplicate tool, but haven't figured how to make the dots around the curve parts using scal3 Share this post Link to post Share on other sites
haumana 985 Posted November 16, 2020 not quite getting the gist of what you're trying to do, with exception to needing holes for a cribbage template. will this work for you? Cribbage-Board.eps Share this post Link to post Share on other sites
darcshadow 1,369 Posted November 16, 2020 I'm not sure in SCALP but in Inkscape you can select an object, then select the point you want it to rotate around. So for this case, you'll have to do the math to figure out the angles, but once that's done, select the 3 circles at the top of the column, set the rotation point the middle circle of the middle column then enter the amount you want to rotate it. Duplicate and repeat till you complete the half circle. If you can't figure out how to move the rotation point, or can't get the rotation point at the exact spot you need, select all 3 circles of both the left and the right column, duplicate and rotate the necessary angle, repeat till you have a full circle then just delete the ones you don't need. 1 Share this post Link to post Share on other sites
Stevem9 1 Posted November 17, 2020 On 11/15/2020 at 6:26 PM, haumana said: not quite getting the gist of what you're trying to do, with exception to needing holes for a cribbage template. will this work for you? Cribbage-Board.eps Oh wow, thats perfect except I need 3 rows of the dots like in the picture above. was that hard to do? I was trying to figure it out. thank you so much for your assistance Share this post Link to post Share on other sites
haumana 985 Posted November 17, 2020 2 hours ago, Stevem9 said: Oh wow, thats perfect except I need 3 rows of the dots like in the picture above. was that hard to do? I was trying to figure it out. thank you so much for your assistance Will a 4-row work? If not, you can erase one of the rows. cribbage 4-row.eps Share this post Link to post Share on other sites
Stevem9 1 Posted November 18, 2020 22 hours ago, haumana said: Will a 4-row work? If not, you can erase one of the rows. cribbage 4-row.eps awesome thank you so much! Share this post Link to post Share on other sites
