CMJ 1 Posted November 15, 2020 I just set my SC2 cutter up and tried to cut. The blade is not dropping down to cut the vinyl. The manual is not helping me. What have I done wrong. I am doing a test cut from the machine. I have a macbook so I am using the surecuts softeare. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 15, 2020 if it is not dropping at all from the test on the control panel of the plotter, then there may be an internal problem with the plotter - if it is dropping and not touching the vinyl to cut then this thread may help you. usually we find as described below the blade holder has been inserted incorrectly or the carriage is off the tracks which the blade holder will drop but not make contact with the vinyl nor cut correctly - 1 Share this post Link to post Share on other sites
CMJ 1 Posted November 15, 2020 Thank you. I will try this Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 15, 2020 that would be at 7:05 in this videohttps://www.youtube.com/watch?v=COJzZyucPdc Share this post Link to post Share on other sites
