dvddvd
vinyl on inside of a window?
Hi all, How would normal vinyl look if you mirrored cut it and then stuck it to the inside of a window viewed from the outside ?
So you would be viewing the adhesive side ? thanks
looks fine if installed correctly but was told more than once at shows from vinyl mfg including orafol that the adhesive isn't uv resistant like the vinyl so they don't recommend it
it would be used on a piece of perspex which is on a lightbox. I could stick it to the front of the perspex but was thinking ofsticking it to the inside of the perspex
it'll depend on brightness of the light, or I should say, the strength of light penetration. try it. you can always take if off if you don't like it.
