jhon 0 Posted October 19, 2020 hello, unintentionally I hit the cable of my plotter and ended up breaking the cable. I would like to weld it again, but I don't know the pinout used. would anyone have the pinout model? (plotter graphtec ce 5000/60) Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 19, 2020 I can't say for sure, but it is most likely a Null Modem cable, 9pin to 25pin. What pins is that green wire connected to? It looks like pins 1 and 7? If so, that's not a normal null modem cable and hopefully someone that actually knows what the cable is will come along soon. Does that model not have a USB port? Share this post Link to post Share on other sites
jhon 0 Posted October 19, 2020 if I redo the pinout as you said (null modem cable) will it work? this model has usb output, but I was never able to use it on usb Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 20, 2020 Will it work? No idea. As I said, just a guess that it is a null modem cable. You can give it a try. I don't believe there is danger of frying something by wiring the cable up as a null modem. Again, I don't know anything about this plotter, but my understanding from reading on here is the USB on Graphtecs works quite well and is the preferred option for most. Why were you never able to use it? Share this post Link to post Share on other sites
jhon 0 Posted October 22, 2020 the computer does not recognize the plotter. I've reinstalled the drive but to no avail. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 22, 2020 Are you sure that the driver installed correctly.? Have you tried a different USB cable.? Which computer operating system? Which cutting software are you using? Share this post Link to post Share on other sites
jhon 0 Posted October 22, 2020 20 minutes ago, MZ SKEETER said: Tem certeza de que o driver foi instalado corretamente.? Você tentou um cabo USB diferente.? Qual sistema operacional de computador? Qual software de corte você está usando? hello, I'm using cutting master v4 windows 10 computer I've tried other USB ports on the computer but to no avail. thought it could be the plotter's usb output. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 22, 2020 Did you put the cutter command on GPGL? It must be for Cutting master Share this post Link to post Share on other sites
jhon 0 Posted October 22, 2020 yes, I put the cutter in gp-gl mode, would the plotter's USB output be burned? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 22, 2020 Try a different cutting software. Signblazer is free use the setup exe download Try the Copam CP-2500 model Command HP-GL http://www.uscuttersupport.com/downloads/Software/SignBlazer/ On Windows 10 does the driver show up in Printers for the Graphtec Ce5000? You could also try a trial of VinylMaster Demo And see if you can at least connect to USB https://vinylmaster.software/ Free demo Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 23, 2020 I'm not a graphtec user, don't they have their own software? Will the ce5000 work with that? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 23, 2020 He was using Cutting Master 4, Graphtec software. "hello, I'm using cutting master v4windows 10 computerI've tried other USB ports on the computer but to no avail.thought it could be the plotter's usb output." Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 23, 2020 16 hours ago, jhon said: yes, I put the cutter in gp-gl mode, would the plotter's USB output be burned? Did you ever try a different USB cable? They can break. I have had broken USB cables before. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 23, 2020 I know nothing about this seller but just used my old friend google to searchhttps://www.ebay.com/i/272246763724?rt=nc&_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D2%26asc%3D225086%26meid%3D6ded8ea99ea64ba9920ee171f9c6376a%26pid%3D100677%26rk%3D5%26rkt%3D30%26mehot%3Dag%26sd%3D282040939411%26itm%3D272246763724%26pmt%3D0%26noa%3D1%26pg%3D2386202%26algv%3DDefaultOrganic Share this post Link to post Share on other sites
