dvddvd 14 Posted September 12, 2020 What are the pros and cons of both types and what would you use for wall art? Seems both are medium tack ? Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 12, 2020 clear will not conform to compound curves and cannot be used when applying wet - usually for walls you use 631 and need a high tack tape - walls can be problematic if textured or painted with an easy clean surface - many times with those surfaces your graphic will be on the floor the next day. 3 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 14, 2020 I keep a roll of 10" clear med tack for a few craft ladies that have me cut them some decals and just HAVE to have clear tape so they can see better when applying. For myself I use paper 100% of the time. Mostly high or high tack R-Tape 4075RLA or higher tack 4076RLA 1 Share this post Link to post Share on other sites
