CutterTech 1 Posted September 3, 2020 Hello, has anyone had success using their cutter when they are connected to a 3.0 or 3.1 type "C" port on a newer Mac. I have tested with a few models and if the communication does happen to work, it always ends up with the dreaded diagonal lines or stops mid cut. Is anyone successfully running their "value" or any model cutter for that matter connected to a Type "C" port? Currently I am testing a US Cutter Laserpoint 1 which worked great on an older Mac with 2.0 ports. It is connected with the supplied USB cable and a USB-C to USB apple adapter. This model uses FTDI drivers and they state there are known issues when connecting to 3.0 ports. https://www.ftdichip.com/Support/Documents/TechnicalNotes/TN_152_USB_3.0_Compatibility_Issues_Explained.pdf I have also tested with the serial cable and a FTDI USB adapter with the same results using Sure cuts a lot, SignCut pro 1 and pro 2, as well as Easy Cut studio. Any feedback or information is greatly appreciated! 1 Share this post Link to post Share on other sites
haumana 1,220 Posted September 4, 2020 What software were you using to cut on a Mac? Which OS version were you on when it worked? I didn't even realize that the LP was Mac compatible, since it only shipped with SBE. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 4, 2020 21 minutes ago, haumana said: What software were you using to cut on a Mac? Which OS version were you on when it worked? I didn't even realize that the LP was Mac compatible, since it only shipped with SBE. Signcut used to be shipped also. It was Mac compatible 1 year license. Share this post Link to post Share on other sites
haumana 1,220 Posted September 4, 2020 3 minutes ago, MZ SKEETER said: Signcut used to be shipped also for the Macs. 1 year. Hmm... I must have missed that. Hahaha. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 4, 2020 Signcut techs used to be very active on the forum.. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 4, 2020 You are going to want to request a tech from SignCut. You will send in a request and they will contact you pretty quick. They are one of the few who have live tech support and they are great people. Share this post Link to post Share on other sites
CutterTech 1 Posted September 4, 2020 Thanks for the replies! Yes, the LP 1 is Mac compatible as it uses the FTDI drivers. http://www.uscuttersupport.com/laserpoint-vinylcutter-setup.html I primarily use SignCut for my Mac computers, the old Mac war running 10.9 but had 2.0 ports to connect the cutter to. (no issues) I just upgraded to a Macbook Pro 10.15 which only has type "C" ports and the cutter is not finishing the cuts, or will cut the diagonal line. The latest version of SignCut Pro 2 also has a new setting to help with these problems "wait until finished cutting" from my understanding, this setting somehow keeps the communication from being interrupted and has worked great with larger files that would normally fail on the old Mac. This setting is not helping on the new Mac though. I'm not sure if it is a driver issue or simply the cutter is not fully compatible with the type C ports. I have installed the driver from the link above, and also the latest driver form FTDI chip. I guess my question is, is anyone else running a "value" cutter successfully connected to a type 'C" port without any issues? Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 5, 2020 20 hours ago, CutterTech said: Thanks for the replies! Yes, the LP 1 is Mac compatible as it uses the FTDI drivers. http://www.uscuttersupport.com/laserpoint-vinylcutter-setup.html I primarily use SignCut for my Mac computers, the old Mac war running 10.9 but had 2.0 ports to connect the cutter to. (no issues) I just upgraded to a Macbook Pro 10.15 which only has type "C" ports and the cutter is not finishing the cuts, or will cut the diagonal line. The latest version of SignCut Pro 2 also has a new setting to help with these problems "wait until finished cutting" from my understanding, this setting somehow keeps the communication from being interrupted and has worked great with larger files that would normally fail on the old Mac. This setting is not helping on the new Mac though. I'm not sure if it is a driver issue or simply the cutter is not fully compatible with the type C ports. I have installed the driver from the link above, and also the latest driver form FTDI chip. I guess my question is, is anyone else running a "value" cutter successfully connected to a type 'C" port without any issues? My wife has a MacBook Pro. Have not tried cutting with it but do you have the dock that plugs in and gives you regular USB and HDMI ports? For the MBPro it utilizes two of the C style ports on either side. It may make the difference Share this post Link to post Share on other sites
haumana 1,220 Posted September 6, 2020 16 hours ago, Wildgoose said: My wife has a MacBook Pro. Have not tried cutting with it but do you have the dock that plugs in and gives you regular USB and HDMI ports? For the MBPro it utilizes two of the C style ports on either side. It may make the difference don't even need a full hub to test it, just find an adapter dongle, or a usb-b to usb-c cable. 1 Share this post Link to post Share on other sites
Susy567 2 Posted September 10, 2020 I have. Didn't have any issues 2 Share this post Link to post Share on other sites
CutterTech 1 Posted October 27, 2020 Susy567, Can I ask what model cutter you are using? Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 28, 2020 Tripp Lite sells an USB-C to Serial adapter, might give that a try. You'll need the serial cable that came with the cutter, most likely a null modem cable. https://www.amazon.com/Tripp-Lite-Serial-Adapter-U209-005-C/dp/B01K2JUUK8 Share this post Link to post Share on other sites
constricted 27 Posted December 2, 2021 I use a TC cutter with Sure Cuts Alot 3 Pro on my 2018 macbook pro with usb 3.1 ports. I use an anker USB C to USB 3.0 adapter and have no issues Share this post Link to post Share on other sites
