Nicolas Arias 0 Posted July 21, 2020 Buenos dias, tengo un plotter de corte MH-871-MK2 y en ciertas partes de su recorrido la cuchilla cae (el electro iman) pareciera que pierde conectividad.- A alguno le paso algo similar. Good mornin i have an MH 871 MK2 cutting plotter and in certain parts of its path the blade falls (the electro magnet) seems to lose connectivity, something similar happened to some Desde ya muchas gracias Thanks Saludos desde Argentina Greetings from Argentina Share this post Link to post Share on other sites
haumana 1,220 Posted July 21, 2020 So does it start cutting then stop? or does it continue to cut the whole job, but miss some parts because the blade doesn't drop down to cut the vinyl? Share this post Link to post Share on other sites
Nicolas Arias 0 Posted July 21, 2020 Keep cutting, the blade does not lift in parts and in others it does Share this post Link to post Share on other sites
darcshadow 1,625 Posted July 22, 2020 Does it do it at the same spot of a design every time? If you rotate the design, does it still do it at the same spot? if it does, that would likely be a design issue. Does it do it at the same spot on the cutter? If it does, that could be a cutting strip issue. The head on the MH raises up when it's powered, so if it's not lifting that could be a wiring/motherboard/z-chip issue. If it's up all the time and not dropping, that could be a motherboard/z-chip issue. Share this post Link to post Share on other sites
Nicolas Arias 0 Posted July 23, 2020 Se cae la mayoría del tiempo y levanta en ciertas partes Share this post Link to post Share on other sites
Nicolas Arias 0 Posted July 23, 2020 En esta foto cual sería mi chip z Share this post Link to post Share on other sites
