wjt
small disc supplied with cutter
what is the small disc supplied with the MH cutter used for? I downloaded Vinyl Master. Do I need to use this small disc for any reason. The cutter comes with a piece of tape over the usb port that says to install software before connecting. is the software Vinyl Master or something on the disc?
Thanks
Bill
I would suspect the drivers for the usb chipset
Here is a list of the files on the disk. Will I need to have the disk in the laptop each time I use the cutter.?
install your vinylmaster - put the disk in the first time when firing up in case it needs it - no once you get it working you can put the disk away
Your PC likely uses amd64 architecture, so open that folder and run the executable file. It'll install the appropriate driver in two seconds.
Then, go ahead with the VM install. Enjoy your new hobby!
