wjt 1 Posted June 27, 2020 what is the small disc supplied with the MH cutter used for? I downloaded Vinyl Master. Do I need to use this small disc for any reason. The cutter comes with a piece of tape over the usb port that says to install software before connecting. is the software Vinyl Master or something on the disc? Thanks Bill Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 27, 2020 I would suspect the drivers for the usb chipset Share this post Link to post Share on other sites
wjt 1 Posted June 27, 2020 Here is a list of the files on the disk. Will I need to have the disk in the laptop each time I use the cutter.? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 27, 2020 install your vinylmaster - put the disk in the first time when firing up in case it needs it - no once you get it working you can put the disk away Share this post Link to post Share on other sites
wjt 1 Posted June 27, 2020 Thanks for your help!! Bill 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 27, 2020 Your PC likely uses amd64 architecture, so open that folder and run the executable file. It'll install the appropriate driver in two seconds. Then, go ahead with the VM install. Enjoy your new hobby! Share this post Link to post Share on other sites
