Sunadan 0 Posted June 11, 2020 Maybe a dumb question but I assume that laser pointer are managed by the software, is it possible to adapt a laser to an older cutter? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 11, 2020 It would probably be easier to find Flexistarter 8.6 v2 or above software. It has it's own contour cutting program in it Works for most any vinyl cutter. No laser needed. . using the blade, in the middle of the registration mark. The software records it. If you do a search online, you can find some instructions to contour cut without a laser. Share this post Link to post Share on other sites
darcshadow 1,626 Posted June 11, 2020 I believe VM has a contour cut ability as well. The laser is just a visual reference to help you line up the registration points. You can do the same using the blade tip, it's just a bit harder to see. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 11, 2020 The laser also complicates the process because it is set off to the side and that offset has to be factored in. Not worth much IMO. Share this post Link to post Share on other sites
