I'm-Lost 0 Posted June 8, 2020 I hope this isn't a silly question. My wife has a business that requires cutting rolls Heat n Bond, which feels kind of similar to parchment paper. Are there any products that will allow us to load a roll of this material and then cut it into 12" sections? The rolls can be cut down to 14" width with a diameter of about 6" prior to loading. Thanks! Share this post Link to post Share on other sites
darcshadow 1,626 Posted June 8, 2020 There are a few higher end cutters that have a cutoff feature where they will cut through the material, but it's for cutting the vinyl off the roll, not for any sort of design. If you're just wanting to cut 12" pieces a good paper cutter would be a lot cheaper. Share this post Link to post Share on other sites
I'm-Lost 0 Posted June 8, 2020 I know nothing about paper cutters, do you have any recommendations? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 8, 2020 Would something like this work? They are out of stock. but maybe can find similar elsewhere. If it would work. https://www.uscutter.com/Mondo-Trimmer Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 8, 2020 Staples store has ROTARY trimmers/cutter and GUILLOTINE cutters/slicers. 2 Share this post Link to post Share on other sites
ayansahor 0 Posted July 31, 2020 I am recently buying a wire cutter. It too sharp. Actually I but it for my home. Thank you Share this post Link to post Share on other sites
