KatieP
Design keeps getting chopped
Is anyone able to look at the attached image and help me figure out why it keeps cutting lines it is not supposed to??  In VinylMaster all of my cuts looks perfect. I tested a smaller version with my pen attachment and it turned out fine. As soon as I make the cut larger it is messing up a ton of the cuts. HELP please!
Images 5413-5415 are how it is cutting messed up. 18-20 is what the rendering looks like in VinylMaster.
IMG_5413.HEIC
IMG_5414.HEIC
IMG_5415.HEIC
IMG_5418.HEIC
IMG_5419.HEIC
IMG_5420.HEIC
If it looks right in the software, but is plotting wonky, take a good look to make sure that the paper is tracking properly.
You might also turn down the speed.
You posted in the MH section so I'm assuming that is the cutter you have. They are very prone to static, do you have the cutter stand/vinyl grounded?
