Market_71 0 Posted May 26, 2020 When trying to put the small soccer ball on the object the black and white get inverted. I want the soccer ball to like the soccer ball in the top left. I have tried using weld and punch. I have also tried using combine. The black vinyl will be put on a wh ite wall. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 26, 2020 I can't remember what terms VM uses to discuss these kinds of things. The ball in question is either a 1 or 2 color object. If 2 color and the white is layered on top of a black circle then ungroup it and just use the white. If its a single color object and what appears white is actually a hole in the black circle it is a compound shape and you can usually release it which will make it a 2 layer object. Sometimes if I am unsure if something is layered or a compound (hole or "knock-out") I will create a new object and change the color and drop it down so it is on a lower layer than the object in question and drag it in behind the object to see if I can see the color show up behind it. When dealing with black and white on a white screen it can get confusing. 1 Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted May 26, 2020 I assuming you're taking the ball from the left and punching it through to get the results. You want the inverse of that so. Draw a circle slightly larger than the ball, then punch the ball through the new circle, then punch that image through the shield image. 3 Quote Share this post Link to post Share on other sites
Market_71 0 Posted May 28, 2020 With the help from both, I was able to get it to work. Thanks Quote Share this post Link to post Share on other sites
