JWofter 0 Posted May 9, 2020 The first image is what it looks like after i cut it. Notice the ander in kommander has dropped but in the top cut which was done at the same time came out fine. Also the right side of the skull cut differently. The second image is how i had it set up on my lap top when i went to cut it. I'm using VinylMaster. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 9, 2020 Show the actual cut vinyl, or use the pen tool on paper and no mention of which vinyl cutter. Operating system? how connected USB or serial" Are you new to this cutter? Do you have experience cutting? Does it do it on every design? Share this post Link to post Share on other sites
haumana 1,220 Posted May 9, 2020 The actual cut vinyl is in the very long link sentence. Are you providing enough slack when cutting? do not pull directly from the roll. There are different factors that could cause that - blade depth, blade force, not enough slack, speed of cut, quality of machine, ... 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 9, 2020 Thanks haumana, now I see the picture of the cut vinyl. Agree. Share this post Link to post Share on other sites
