Infinity Clothing 0 Posted April 11, 2020 Hey Guys, I am a very new, newbie here and do need some help (by newbie, I literally mean my first Heat Press machine arrived yesterday and I ordered my first Vinyl Cutter today). I have ordered the MH721, now I have read about how it's not amazing etc - please leave the 'upgrade' comments out of this as that is not an option. Since I ordered it and done some research and saw that a lot of people were struggling to connect it to a MacBook. So, here's what I need help with. - What is the best software to cut with on a Macbook with the MH721. I ideally need this to be free, a monthly subscription or very cheap (I have heard about SignBlaze being free?). Again, I don't want any expensive comments.. I am on a very tight budget. I just want a software I can import my designs into and cut. - Are there any complications connecting the MH721 to a macbook? Will I need anything other than the standard lead? It is second hand, it comes with the cutter, power cable, coms cable and installation disk. Hoping someone can help me. Thanks! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 11, 2020 Here is your answer The MH Series Vinyl Cutter is available in 14", 28", 34", and 50" sizes. Cutter not Compatible with Mac. Posted on all USCutter ads. You will not get support for something that is clearly advertised as NOT compatible. Maybe if ran on Windows Parallels, Bootcamp etc. Signblazer is Windows only. 1 Share this post Link to post Share on other sites
haumana 1,220 Posted April 11, 2020 People struggle because it's not compatible in native OSX. Like Skeeter said, if you Bootcamp, Parallels or VM Fusion, and load Windows on it, then you can run a Windows based cutting software. Sign Blazer is free and will definitely work. That's the workaround that will work. Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 11, 2020 Dell Latitude e5500 will run you around $50. on eBay. If you cannot absorb that cost into your budget, then your "business" plan is totally wrong. SignBlazer will work (RedSail driver) with either USB or Serial com --- the e5500 has a legacy serial port and 4 usb ports. Best advice I can give you as an HTV Very New Newbie === mirror. Share this post Link to post Share on other sites
Infinity Clothing 0 Posted April 11, 2020 Okay, so, I have got a windows desktop now (found an old PC). So now, my next problem is, I now need an adapter for the coms lead to a USB as they are the only ports I have available. Share this post Link to post Share on other sites
bikemike 711 Posted April 11, 2020 Old PC with a serial port or only usb? If serial just use a null serial cable to the cutter. If only usb, use a "keyspan" usb to serial with the null cable. 1 Share this post Link to post Share on other sites
haumana 1,220 Posted April 11, 2020 Any 'old' PC should have a standard USB-A port. Doesn't MH Machine have a USB-B connection, or just a serial? You can try with one of the other, but not both simultaneously. 2 Share this post Link to post Share on other sites
darcshadow 1,625 Posted April 13, 2020 If the old PC has a serial port then that's the ideal setup. The USB interface on the MH is less than ideal and if you can use the comm port that is a much more stable connection. 2 Share this post Link to post Share on other sites
