GHEENEE1 2 Posted April 9, 2020 The 45 degree blade offset I have set for my Titan 2 is .30, is this a correct setting? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 9, 2020 there is no set in stone number. Start at 0.25mm and do test cuts with the TEST feature and see what looks the best. You must first make sure you have the blade depth set correctly. That is posted hundreds of times in this forum. Do not use the thickness of a credit card. 1 Share this post Link to post Share on other sites
GHEENEE1 2 Posted April 9, 2020 Thank you! .30 works, just checking. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 9, 2020 Each cutter will be different, even the same model. Adjust to what works. Your welcome 3 Share this post Link to post Share on other sites
haumana 1,220 Posted April 9, 2020 Every machine is different, as well as blade/blade brands. Trial and error. My original LP offset sweet spot is .26 or .27 depending on blade/blade brand. Like Skeeter said, start with .25, then go from there. 2 Share this post Link to post Share on other sites
