87westy 1 Posted March 29, 2020 Can someone point me to a written or very clear video on how to use the edit node features? I've been working on this for a few nights and I can't make it do what I watch in the videos...Pulling my hair out TIA Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 29, 2020 Without some more information it's hard for us to know what you want to do. Bear in mind the "Cut" version is the most basic and is limited as to what you can do. Here is a comparison chart so you can see if maybe it's just a limit in your version or not. https://www.uscutter.com/static/PDFs/VinylMaster_Comparison.pdf 1 Quote Share this post Link to post Share on other sites
87westy 1 Posted March 29, 2020 Really, I'm just trying to join two letter I's together at the ends. A few times i've been able to weld and break curve but nothing close to consistent results. My bank is blocking a purchase to upgrade tonight, I have not clue why are are not authorizing it...It will be Monday until I can speak with them Quote Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 29, 2020 (edited -- this is a VinylMaster thread, no need to promote SBE here) Don't pull your hair out, because barbershops are closed by Emergency Order~~~~ 1 Quote Share this post Link to post Share on other sites
87westy 1 Posted March 29, 2020 i figured it ut... Move the nodes you wish to combine into the other other object... Click combine while the nodes are hightlighted. Select Weld Select Brake Curve and delete what you overlayed in the first step. I was way over thinking it... 1 Quote Share this post Link to post Share on other sites
haumana 1,220 Posted March 29, 2020 thanks for keeping us updated. Quote Share this post Link to post Share on other sites
