jhospfer 0 Posted March 21, 2020 MI PLOTTER HACE UNOS DIAS VIENE CORTANDO LAS LETRAS MAL Share this post Link to post Share on other sites
haumana 1,220 Posted March 21, 2020 Qué quieres decir Share this post Link to post Share on other sites
jhospfer 0 Posted March 31, 2020 On 21/3/2020 at 18:14, haumana said: Qué quieres decir Hola.... Adjunto la foto del text de mi ploter y te puedes dar cuenta que la estrella esta mal cortada, lo mismo pasa con las letras en especial con las letras redondas las desfigura. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 31, 2020 This is the correct way to set your blade depth, then start with blade offset at 0.25mm. This is correct way to set your blade depth. To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. You should just barely see and feel your blade tip out of the blade holder. Share this post Link to post Share on other sites
