Guest Jimmy Hines Posted March 17, 2020 I have a project that I need to edite one line of the text that is too thin for weeding after cutting on my cutter. Can anyone tell how to select that part of the design so I can edite the text to make it thicker Any help will be appreciated. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 17, 2020 Jimmy you will have a better experience if you sign in to the forum. As it is a moderator has to approve each of your posts since you are a guest. Thank you. 1 Quote Share this post Link to post Share on other sites
haumana 1,220 Posted March 17, 2020 First you have to determine if the text is even editable. If so, then selecting the text tool should do it. 1 Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted March 18, 2020 In VinylMaster, you can add a Stroke to either Editable Text OR Text that has been Converted to Curves. ( any Object really ) After adding a Stroke with the 'Outline Module' Weld the Text to the Stroke together for added thickness. As far as Selecting just that Line of Text to add the Stroke to; Depends on whether its been Welded to other Objects or is still separate. Worst Case; You may have to Duplicate the Line and Thicken that one and Delete (Replace ) the Original with it. 1 Quote Share this post Link to post Share on other sites
Jimmyhines66 0 Posted March 18, 2020 Hello folk, I have a logo that I'm having a little problem with . I vectorize it in vinylmaster but when I weeded it out after cutting it put on my Sc cutter one section of the lettering was real thin and I wanted to give it a thicker stroke or maybe even using a different text all together. Can anyone help me with this. I've tried ungrouping the design and then tried to select just that part but for some reason I can't seem to select it to edit it. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted March 18, 2020 Go to the Calibration tab in the Vinyl Spooler and run through the Blade Offset wizard. Quote Share this post Link to post Share on other sites
haumana 1,220 Posted March 18, 2020 I merged this thread, since it's the same OP asking the same question. Jimmie - thank you for taking the time to sign up to be forum member, I encourage to be patient when posting a question, rather than re-post it with a different title. The forum is comprised of volunteers who try to get the questions answered as quickly as we possibly can, but there are times that it just takes time, and someone who might have the answer to check the forum and get back to you. Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted March 18, 2020 Ungrouping may not be enough. You might need to break apart the design. I'm not sure how or if this is possible in VM. Inkscape would be my go to for something like this. Can you post an image of the design, might help with offering suggestions. Quote Share this post Link to post Share on other sites
