Why won't vinylmaster vectorize my image i edited ? I'm messing with an image and i split it in half using nodes. I vectorize it and the image vectorizes as if i never even messed with it
Sounds like you need some VinylMaster assistance -- not a cutter hardware (SC-related) issue at all.
"I'm messing with an image and i split it in half using nodes.." -- images are composed of pixels, not nodes.  (Raster/Vector)
Anyway, even though your first post is miscategorized here, jon, you're gonna have to be able to provide more details (including the original file, so we can see it for ourselves ----- right now you got us imagining your problem in the dark).
When you say split it in half using nodes, what are you meaning? A raster image can not be edited using nodes.
You need to either edit the image in a raster image editor such as Photoshop, or convert it to a vector and edit it using a vector program such as VinylMaster.
Even though you only want half of the image, the easiest way would be to vector the entire thing, then draw a box over the half out don't and do a punch through to delete that half. I forget the actual term used in VM, punch through might not be the right one.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
