Leach 0 Posted March 5, 2020 New to FlexiSIGN. After making a square is there a way to make two of the corners rounded but not the other two? Share this post Link to post Share on other sites
dwp99 283 Posted March 5, 2020 Yes there is a way to do it. After you've made your square, in Design Central click the third tab over (Red Arrow). Go down to third window down and click rounded then the next window down to round the corners (Green Arrows). Once you get the desired amount of roundness all 4 corners will be rounded over. Next with the square you drew highlighted click on the Arrange tab (blue Line) go down to the convert to outlines (Blue Arrow) and click on it. Now under the Path Edit (I have mine pinned to the top toolbar) Click on the Sharpen corner tool (Purple Lines) and click on both sides of the corner you want to to remain square. Once you click on both sides you'll need to double click or hit enter. 1 Share this post Link to post Share on other sites
