Hi I’m Jeanny I’m very new dealing with this type of machine and this cutter is not making the whole cuts
I mean... when I’m making a circle or a letter it not cutting all the way
idk what’s wrong :wacko: I need help
 No mention of what software you are using, or how you set your blade depth, or blade offset. Please explain how you set this cutter up for cutting. What do the test cuts from the machine look like? You have to start with getting the test cuts right first. Have you ever ran a vinyl cutter before? If so, which brand?   I have a version of this machine, only it's the MK2-75..
