sayitwithink 0 Posted February 11, 2020 Help! My Titan 3 stops cutting midway. The attached picture is what is showing while cutting but at that point the cutter would stop and although the cut hasn't been completed the computer shows "sent to cutter" and blue line is all the way though. I've restarted my computer, turned on and off the cutter, and rechecked the connections. How do I fix this issue. I'm wasting a lot of time and vinyls here. Pleas help. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 11, 2020 Does it stop with every design or just this one? Does it stop if you just type some text? Use your pen tool until you get it sorted out. No mention of which cutting software on which computer operating system. 2 Share this post Link to post Share on other sites
haumana 1,220 Posted February 11, 2020 Is it stopping in the same place each time? If so, try rotating the text, re-cut and see if it still stops in the same place. Is your text, actual text typed in - or is it vector graphic? Share this post Link to post Share on other sites
