rex 7 Posted January 22, 2020 search didnt hel[p,,i used signblazer with my us cutter and got real comfortable with it,,then i got a roland gs 24 which came with cut studio,,,im not to fond of that,, i cant get signblazer to use the gs24, ive picked every plotter option and no luck,,any ideas, or am i stuck with cut studio? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 22, 2020 so from your description I take it you installed the usb drivers for the plotter and tried the older roland drivers in signblazer? heck all the old rolands thru the gx-24 would use the old pnc-24 drivers. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 22, 2020 I see years ago you had trouble setting this plotter up when you got it . . .did you select the right port in signblazer? Share this post Link to post Share on other sites
rex 7 Posted January 22, 2020 Yea,the original problem was it just needed a restart after instalation,ive been trying to give the cut studio a fair shake,but I dont like it as well as signblazer Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 22, 2020 what port do you have selected in signblazer set up for your plotter? which plotter did you select also? Share this post Link to post Share on other sites
rex 7 Posted January 22, 2020 I've tried all the plotters, not sure of the port,I'll check that tonight Share this post Link to post Share on other sites
rex 7 Posted January 22, 2020 Ok,I'm using USB is that what you were meaning by port Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 23, 2020 1 hour ago, rex said: Ok,I'm using USB is that what you were meaning by port maybe slice n dice can chime in as our signblazer expert but seems like it should be a roland usb port - as I recall my signblazer showed several usb ports but it has been 12 years ago Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 23, 2020 I'm going to move this to the signblazer part of the forum as that is where you really need help Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 23, 2020 rex, Two things -- 1. Uninstall your SBE and restart your computer. Download and run the v7.0.0 version HERE -- http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe 2. Make sure you install the USB emulation driver http://www.uscuttersupport.com/downloads/Drivers/cdm20828_setup_windows.exe Let's see how that goes. 1 Share this post Link to post Share on other sites
rex 7 Posted January 25, 2020 that was the trick,thank you very much 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 25, 2020 Bingo. Y-W. Share this post Link to post Share on other sites
