billeoff
billeoff
New at cutting ----question i got some 813 oramask can i cut this with my us cutter mh817  34 inch ?
will i have to use 60 deg blade ?
will i have to put more pressure on blade if so about what setting ?
will i have to slow down speed of feed about what setting ?    THANKS FOR ANY HELP
Sure, you can cut it, nothing unique about that product, it goes right through the machine just like regular vinyl or HTV.
No, you don't require a 60* blade. I know that Flock Material and Reflective Vinyl require a 60 degree blade for smooth cutting. It won't hurt anything to use 813 vinyl with the 60* but you don't need to.
As for pressure and speed, it doesn't seem like you have to make any special adjustments, but run a test and verify.
And for the record, you are NOT going to be cutting all the way through the backing. Just cut the vinyl, peel away the graphic, and use app tape, basically the same as any other vinyl project. The thickness of the material (2 mil), is standard for the capabilities of a 45* blade.
