Seaside Embroidery 0 Posted January 14, 2020 Does anyone know if you can do contour cutting with the mh-871 mk2? I'm using Vinyl Master Cut, and the software supports it. I found a YouTube video of someone doing CC with this same plotter, but I'm not having any luck! Share this post Link to post Share on other sites
MZ SKEETER 4,495 Posted January 14, 2020 The Refine Mh cutter from UScutter does not have an optical eye to use with Vinyl Master to contour cut. There are MH cutters that have an optical eye, laser. That may be what you saw on youtube. Cutters overseas do. It could be used with a Flexi product. The Flexi products have the contour cutting program in the software, it's self. You use the blade in the center of the registration mark to set it up for contour cutting. The next cutter up, the SC2 can contour cut. And is a much better cutter over the MH cutter anyway. 1 Share this post Link to post Share on other sites
darcshadow 1,395 Posted January 14, 2020 Technically any plotter can contour cut, the trick is getting everything lined up correctly. When you say you're not having any luck, what exactly is the problem you're having? So long as the design is not too large or complex the tracking on the MH should be good enough to do contour cutting, it'll just be a matter of getting things lined up right to start. 1 1 Share this post Link to post Share on other sites
Seaside Embroidery 0 Posted March 13, 2020 I 'm using vinyl master software and it has a wizard for contour cutting. I line every thing up as it shows but when I start to cut it runs off the paper. Share this post Link to post Share on other sites
haumana 1,008 Posted March 13, 2020 contour cutting is basically an outline of the overall design. are you printing something on paper, then trying to contour cut it? Share this post Link to post Share on other sites
APJusto 0 Posted September 21, 2020 @darcshadow Do you have any tips for getting an MH 721 lined up? That has been my biggest problem trying to do contour cuts. I'm willing to try anything. Thanks. Share this post Link to post Share on other sites
slice&dice 2,235 Posted September 21, 2020 What are you trying to contour cut? Show the file. Share this post Link to post Share on other sites
darcshadow 1,395 Posted September 22, 2020 I've never actually done it and don't exactly know how VM works but basically, you load the material with the image printed, and tell VM you want to contour cut. It should then prompt you to move the cutter head to the the registration marks and then start cutting. Again, I've never actually done it, but there's no reason it shouldn't be possible, maybe just not as easy as with other cutters. When I get some time I might play around with it a little and see what I can do. Share this post Link to post Share on other sites
xdesign305 1 Posted October 6, 2020 i found this video and I have tried it also. It works!!! 1 Share this post Link to post Share on other sites
