Tony chamu 0 Posted January 7, 2020 Does anyone know if the graphtec CE6000-120 AP can cut vinyl? All I see is plotting and cutting regular paper. Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 7, 2020 where are you seeing that? If I do a google search for CE6000-120 AP everything comes back withGraphtec CE6000-120 Vinyl Cutter. Share this post Link to post Share on other sites
Tony chamu 0 Posted January 7, 2020 https://www.graphtecamerica.com/vinyl-cutter-cut-plotter-ce6000-ap it doesn’t really say much about vinyl Share this post Link to post Share on other sites
Tony chamu 0 Posted January 7, 2020 7 minutes ago, darcshadow said: where are you seeing that? If I do a google search for CE6000-120 AP everything comes back withGraphtec CE6000-120 Vinyl Cutter. https://www.graphtecamerica.com/vinyl-cutter-cut-plotter-ce6000-ap Share this post Link to post Share on other sites
bikemike 711 Posted January 7, 2020 I will give you that one. The AP does say for paper and such. Didn't read the full specs, stopped at the pattern part. Share this post Link to post Share on other sites
Tony chamu 0 Posted January 7, 2020 10 minutes ago, bikemike said: I will give you that one. The AP does say for paper and such. Didn't read the full specs, stopped at the pattern part. It doesn’t say much about vinyl Share this post Link to post Share on other sites
bikemike 711 Posted January 7, 2020 1 minute ago, Tony chamu said: It doesn’t say much about vinyl I don't think I have head of anyone on here that has the AP version. Share this post Link to post Share on other sites
Tony chamu 0 Posted January 7, 2020 5 minutes ago, bikemike said: I don't think I have head of anyone on here that has the AP version. It must be a low selling cutter Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 8, 2020 That's pretty wild. AP = Apparel Pattern. Looks pretty specialized and I would wonder if it can be used for vinyl or not. Definitely not what it was designed for although the rest of the spec seem similar to the regular CE cutter. Share this post Link to post Share on other sites
Tony chamu 0 Posted January 8, 2020 3 hours ago, Wildgoose said: That's pretty wild. AP = Apparel Pattern. Looks pretty specialized and I would wonder if it can be used for vinyl or not. Definitely not what it was designed for although the rest of the spec seem similar to the regular CE cutter. That’s what I’m trying to find out it seems similar but it’s confusing Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 8, 2020 If your looking for a vinyl cutter, then why not search for a vinyl cutter Why would you want this? It states it does not use up and down like a regular vinyl cutter. It uses force. You would probably only need force for paper. It also states that it checks the paper for temps. so that the paper is right right temp to cut. (ambient temperature and humidity) The way it sounds also is that it only cuts perf like cuts and dashes for patterns. It does not state that you can use regular cutting software with it. It sounds like it has it has this pattern software that creates the dashes and perf cuts. Contact Graphtec tech support. Perforation cutting is performed by controlling the cutting force instead of blade up/down movements - dramatically increasing throughput. The force is controlled by the design software using a new command. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 8, 2020 I would at the very least get in touch with a dealer and get the real info. They may tell you that it's fine for regular too. I can't imagine needing 450g of force for any paper cutting so it is at least based on the regular platform. The up and down force thing is how Summa does their perf cutting for contour cutting printed stickers so that may just be a setting. I am making the assumption that you found a good price on a used one somewhere is why you are looking at it. If buying new then don't waste your time. Share this post Link to post Share on other sites
Agnese 0 Posted March 13, 2021 Hi, this plotter is for apparel industry. it’s modified to plot paper or card pattens for fashion industry. I am looking for plotter like that. let me know if you want to sell. Share this post Link to post Share on other sites
