kp signs
sk720t
hi all,
i have an sk720t cutter which i recently purchased. i have set up all the coms and for some reason when i hit CUT, the data is transferred but there is no response from the cutter??
i have reconnected a few times and same problem. i am running on windows 10 and have a serial to USB connection. any help would be greatly appreciated. thanks.
Which cutting software are you using?  Did you make sure the driver installed correctly?  Com port numbers are matching in computer device manager and the cutter software?   Is that a used cutter?  Did you see it cut before buying?  Did you try a different cable?  Best to put it on a Tripplite Keyspan Adapter,   it does work with a vinyl cutter.
I have the same problem with windows 8.1 all data transferred but no cut.... I've tried to install the usb lead in beginning but with a 1000 attempts and help from cuz who's a wizz kid on computers I just couldn't get it to work even with installing and uninstalling everything
So I bout a com port to usb lead now I got it connected I send the data but wont cut did u sort this after could u help please I'm started to loose my shit now lol
Thanks in advance
With value cutters best to use  a Tripp-Lite Keyspan  Adapter. Is guaranteed to work with a vinyl cutter. Many of the cheap USB to serial adapters have the same cheap chipsets like the vinyl cutter.   For reference only, find the best price.
https://www.amazon.com/Tripp-Lite-Keyspan-High-Speed-USA-19HS/dp/B0000VYJRY/ref=sr_1_3?crid=1BN0WAUK1WM7X&keywords=tripp-lite+keyspan+usb+to+serial+adapter&qid=1581457743&sprefix=Tripp-lite+keyspan%2Caps%2C204&sr=8-3
As Skeeter has already asked - what software are you using to cut? You've checked the com port, but have you configured your cutter software to be matching? Depending on the software you're using, is there a specific driver in the software, or is there a list that you're working to find a compatible one?
Have you tried to download other cutting software? You can download the trial versions of several other programs, and see if those will communicate successfully with your cutter.
Have you tried doing a test cut, from the cutter interface/control panel?
