teddyu 2 Posted November 21, 2019 I just got a stand for my MH 721 put it together and sat the cutter on it and the blade will not go up or down now. Can anyone help? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 21, 2019 Did you use a ground wire and ground the cutter to the stand? You should, as the static from the vinyl will go thru the carriage head and fry the z chip. Can you manually lift the blade holder up and down? Share this post Link to post Share on other sites
teddyu 2 Posted November 21, 2019 No I did not ground it and yes you can move the holder up and down. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 21, 2019 from another forum member posting, This has has been posted many times " guess is a z-chip on the mainboard if it had been working fine before. you can take the cover off the carriage and try touching a 9v battery to the wires to see if it reacts - if it does then change the z-chip - if it doesn't then carriage" Share this post Link to post Share on other sites
