Busdriverfella 1 Posted November 12, 2019 Computer took a dump. Microsoft won't restore from the backup (thanks for that, Microsoft), but I can still mount the backup and copy data off of it. If I know where the configurations file(s) or registry key(s) are for SB I can copy that over and (hopefully) be back to where I was without losing anything. As it is, it doesn't know it's a registered copy, or that I have a cutter, or ANYTHING. If anyone knows where the config info is stored, that would be a great help! Much better than starting from scratch anyway! Thank you for your time. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted November 12, 2019 Signblazer is FREE software. Just download it. Does not require registration http://www.uscuttersupport.com/downloads/Software/SignBlazer/ Share this post Link to post Share on other sites
haumana 1,220 Posted November 13, 2019 I think your best bet will be to download the software from the link that Skeeter listed, then just set it up again from scratch. I'm not sure if any of the SBE users here know where to find the files that you're looking for. It sucks to have to start from scratch again, but it's a means to the end. At least it's free Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 13, 2019 Apparently you have access to all the old SBE graphics files (located in a folder called SBD, at the top-level of your C: drive) so all you need is a fresh copy of the program. Download it and install from HERE - (skeeter's link is to a general Directory, containing several options, but this link is direct to the actual V7.0 installer) http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe (disable your anti-virus defender or it will attempt to prevent SBE. The reason is the program has been 'cracked' internally to eliminate the nag screens at startup and bypass the registration scheme). Share this post Link to post Share on other sites
Busdriverfella 1 Posted November 13, 2019 I have the software on the drive (from the backup), but just need the config location(s) to reload that. Seems to be well hidden I guess. Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 13, 2019 Re-install SBE using the download I've provided. Share this post Link to post Share on other sites
