Bevan 0 Posted October 29, 2019 Hi Guys I have stumbled upon a Refine EH721 Vinyl Cutter and only have access to Windows 10 Pc's (Laptop) and no matter what Forum I read and what I do, I cannot seem to get it to connect the Laptop. I am using a cable that goes from the Cutter to a USB, its Called a RS2320 to USB, I have tried many different drivers but feel I am doing something wrong. I'm not super smart with this stuff but I usually do figure it out. I have downloaded many different Cutting software including Signblazer. Is there something I'm missing? Much appreciated thank you. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 29, 2019 You will first need the driver for your particular usb to serial adapter. Most success here in the USA has been with the key span brand. What cutting software will you be using? Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 29, 2019 You probably need a null modem cable as well. You typically can not connect a usb-2-serial directly to the hardware. You usually need a straight serial cable or a null modem cable. If the EH is the same as the MH you need the null modem cable. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 29, 2019 good point darcshadow Share this post Link to post Share on other sites
Bevan 0 Posted October 31, 2019 Thanks guys Cutting software i'm using now has been Signcut or Coreldraw and the other one was easy cut studio. None seemed to work If I may ask, what is Null modem cable? Share this post Link to post Share on other sites
Bevan 0 Posted October 31, 2019 On 10/29/2019 at 9:42 PM, Dakotagrafx said: You will first need the driver for your particular usb to serial adapter. Most success here in the USA has been with the key span brand. What cutting software will you be using? Im also happy to use any software that will work, suggestions on software that will work I will use. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 31, 2019 1 hour ago, Bevan said: Thanks guys Cutting software i'm using now has been Signcut or Coreldraw and the other one was easy cut studio. None seemed to work If I may ask, what is Null modem cable? signcut will work with creations in corel or ECS - a null modem serial cable has a different pin configuration from a regular serial cable - the refine MH series requires the use of a null modem cable to communicate to the plotter as darcshadow indicated. you also as mentioned before have to use the proper drivers for the chipset in any serial to usb adapter you are using Share this post Link to post Share on other sites
