Pwdrit
Graph ref Ce6000 60 vs 120
Hello. I have been looking into getting a vinyl cutter and have decided on the graphtec ce6000. This will be the first vinyl cutting machine I have owned. I do some powder coating on the side and want a vinyl cutter to be able to cut more complex maskings and graphics. I can see that I will have the opportunity with the cutter to add another potential income stream. What I’m trying to decide is how much more opportunity the ce6000 120 will provide. Or would I be better of getting a printer to do color graphics to compliment the 24” machine. Thanks I value others knowledge and experience.
if you have never done vinyl graphics you really can't related to how hard it is to weed and then mask anything over 30" wide - I owned one 50" and several 24" after that.  almost all signs can be cut and applied in segments a 24-30" plotter can do and much easier to handle.  I also owned a 54" roland printer and then 2 30" rolands - great print/cut machines and I always kept my graphtec around for the vinyl side even though technically the print cut machine would have functioned as both it would not do as good of a job on small detailed cutting.   when you make the leap on the printing side have $15K-$20K ready to start and keep it busy all the time - solvent printers do not like sitting and will remind you with requited replacement heads and other maint items as when the heads clog there is no cleaning them like a water based desktop printer you might be used to.  I always budged about $1K a year for maint on the printers
I use a 30" cutter and I would never want one any wider....I have a 30" 8ft table and it works perfect for masking. I only cut vinyl.  A lot of my jobs are pretty detailed and the Graphtec does a great job for that.
Thanks guys. That’s great info for me. I’m just getting going and I want to buy the right equipment so I can grow with it. I had wondered about what you said Dakota about breaking up larger jobs in segments. I have been leaning towards the graphtec. There seems to be a lot of instructional videos out there which I will need. I fairly new to this so there is a big learning curve ahead. So a user friendly machine is important. Hopefully I can turn it into some decent income. Thanks again guys you info is greatly appreciated.
the graphtec comes with the graphtec pro studio software too that is worth as much as the plotter so it is really a great deal
Thanks for the info Dakota. The graphtec definitely seems to be the best option.
