eriksonx
help garaphtec ce 5000-40 craft robo pro
hi everyone, im a super newbie, looking for help so go easy on me, I cant seem to get the drivers installed correctly on my Graphtec craft robo pro CE5000-40.  the machine shows up as usb printing support unspecified. ive already tried updating the drivers, ive uninstalled the drivers , ive went thru serveral tutorials, but the machine when plugged in , shows its a usb print suport
Is your machine hooked up via USB or via serial port?
which version of windows are you running on?
what software are you trying to use for cutting?
All of my Graphtecs show up in the printers.  So what is your problem?   They have a real USB connection.
what Haumana said - what software are you using for cutting your vector graphics
I meant it shows up as "unspecified" usb printing support
Which  cutting software?    Have you set the cutter up to your software? Have you plugged the cutter into your computer and tried to cut?
CorelDraw x7 cutting master 2, yes ive plugged it in and it syncs forever. I also tried using the graphtech studio. im now confused by the whole set up, is the ce5000-40 too old to use with windows 10.?  do I even need the drivers to cut? like I said im a newbie im gonna ask newbie questions
Which COMMAND do you have the cutter on?  It has to be on GP-GL for Cutting Master.   It would be fine on Windows 10.   You can even run that cutter on FREE Signblazer,  If on Windows.    If you try Signblazer, COMMAND has to be on HP-GL.
1 minute ago, MZ SKEETER said:
Which COMMAND do you have the cutter on?  It has to be on GP-GL for Cutting Master.   It would be fine on Windows 10.   You can even run that cutter on FREE Signblazer  If on Windows.
its on GL-GL, is there a way to back my way outta the mess I created and start fresh, ill look at sign blazer, if its a bit easier to work with.
8 minutes ago, eriksonx said:
thank you MZ SKEETER. appreciate your help.
Your welcome.  I hope you can get things going.
Your CE5000 is not listed,  try one of the lower ones.  Maybe they will work.  Maybe not.  You may have to buy software.    If all you need is cutting software.  And you have Windows, you can get Vinyl Master.
https://vinylmaster.software/
The ce5000’s I had worked with ce3000 drivers
Your first problem is Windows 10. I'm not railing on Windows because I'm 85% Mac user. I run my laser from a Windows 10 machine, with CorelDraw - and that last  update Windows pushed out was a dozey. I thought CD was broken. I don't know how many times I uninstalled and reinstalled the software, and I even uninstalled the stupid update, and it was never the same. I still have a huge latency issue when sending files to 'print' to the laser. Mind you, some files are very small - just simple text. So if you can, use another machine that is either Win7 or earlier.
Definitely give SB a try. It looks a little antiquated and a bit like a kids program, but it's a workhorse and can get the job done.
Keep us posted.
Keep us posted.
yes that's exactly when I began having issues, shortly after the last update. then again I seem to take anything computer related like  its a rocket science course, when in fact it was a super simple set up... I got it working after a week of frustration, high blood pressure, and the invention of tons of new cuss words....and now I shall cut away. …..thank you for responding …….y'all are the best!...
I got it working Mz. Skeeter, thank you for your quick response and helpful knowledge. much appreciated.
