Worble7
Multi color Vinyl help
2 minutes ago, Worble7 said:
ahhhhh I see. Thanks
You can use any kind of little shape that you want for registration marks.  circles. triangle, stars.  But if you go into FILE> shapes tools, you will see  the registration mark tool.   You can make them different sizes as well as place anywhere.
just add a couple of your own marks - I like stars, some like diamonds, etc 2 at the top and copied over each other in layers for each color works great for layering vinyl - lots of youtube videos on layering
So this video is longer than it needs to be, but you'll get the idea.
If i were doing something similar to cookie monster, but only needed to cut 2 of the 3 colors (because it is a 3-color graphic), then I would cut the black out as one piece (solid with exception to the eye balls), then cut the blue and layer that on.
As far as alignment goes - I would also add two squares in the top corners and it would get cut with the black and the blue. tape up the blue, then use the squares of the blue to align it over the black.
voila!
