Dakotagrafx 7,297 Posted October 21, 2019 grandkids here today so won't be able to track down the link for the update - doesn't scal have a update link in the menu like most other programs? back to runny noses and crying for a while - will try to check back later Share this post Link to post Share on other sites
GailNasiatka 4 Posted October 21, 2019 US Cutter Support has fixed the issue. Thank you Greg. Thank you everyone who tried to help. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 21, 2019 As a side note, if you have your other cutters blade depth at a credit card thickness, you will want to fix them with my instructions, that is way too much blade exposed. You should barely see and feel the blade tip, You only cut with the very tip of the blade. And start your blade offset at around 0.25mm and work in small changes to get the offset correct. 2 Share this post Link to post Share on other sites
GailNasiatka 4 Posted October 21, 2019 16 minutes ago, MZ SKEETER said: As a side note, if you have your other cutters blade depth at a credit card thickness, you will want to fix them with my instructions, that is way too much blade exposed. You should barely see and feel the blade tip, You only cut with the very tip of the blade. And start your blade offset at around 0.25mm and work in small changes to get the offset correct. I did exactly that. US Cutter took care of the re-install with the patches. My blade is adjusted as you described. ALL IS WELL! Thank you all again Share this post Link to post Share on other sites
David@USCutter 39 Posted October 21, 2019 1 hour ago, MZ SKEETER said: Maybe it's me, But it says the Token is expired for that fix link for the update. It wasn't just you, it had expired, I have just updated the link in the other thread, and I'll link it again here in case anyone else finds this thread.Here is the link to the newest version of Sure Cuts A Lot 4 Pro for Mac. 3 Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted October 21, 2019 14 minutes ago, gailherran said: I did exactly that. US Cutter took care of the re-install with the patches. My blade is adjusted as you described. ALL IS WELL! Thank you all again Now that your back in business, and your Prisim is running good. let us know the pros and cons of it. We haven't heard from anyone who has bought it. Share this post Link to post Share on other sites
GailNasiatka 4 Posted October 21, 2019 Other than that it is good so far. It't not as quiet as I expected. The Wi-Fi works great. Plus I need to spend more time here on the forum so I can learn. After 13 years of doing this, I am sure there are lots of things I can learn Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 21, 2019 1 hour ago, gailherran said: Other than that it is good so far. It't not as quiet as I expected. The Wi-Fi works great. Plus I need to spend more time here on the forum so I can learn. After 13 years of doing this, I am sure there are lots of things I can learn being a stepper motor I wouldn't think it would be super quiet but usually the higher end stepper motor cutters with finer resolution are not as noisy as the cheaper units. will be curious to see how many select this for the wireless over the servo motor titan2,3 etc Share this post Link to post Share on other sites
GailNasiatka 4 Posted October 21, 2019 1 hour ago, Dakotagrafx said: being a stepper motor I wouldn't think it would be super quiet but usually the higher end stepper motor cutters with finer resolution are not as noisy as the cheaper units. will be curious to see how many select this for the wireless over the servo motor titan2,3 etc My Titan 3 is a good cutter too. Quieter than my MH721. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 21, 2019 Jet aircraft are quieter than MH's. lol 1 3 Share this post Link to post Share on other sites
