Heathw
Cutting at the beginning
Whenever I start a cut the first 2 letters are up higher then it picks up and does the rest of the decal right. Does anyone know what’s causing this?
We will need more info. What cutting program are you using? Is this on every job or just one? If it's not copyright protected up load the cut file in EPS format and we will take a look.
It’s the vinyl master LTR V4.0. It wasn’t doing this at the beginning. It just started every test piece of vinyl I’ve run which is about 10 pieces it has done it
It’s post to say Works the S and K are messed up then after that it cuts the rest out like it’s post to be
Have you looked at the file in wireframe to be double sure that the file itself is good. Of you are cutting scraps have you told the cutter what size of material scrap you are cutting on?
What is the big gouge at the top of both K's?    What kind of vinyl???   looks a lot like the blade is cutting thru the vinyl on the top of the k and top of the s and causing slippage - like the blade is set with too much exposure . . . .
