diver4 1 Posted September 10, 2019 I am using VM LTR and on occasion the toolbar (with red box around it in the picture) disappears and the only way I have found to get it back is to shut down VM and restart it. Is there a way to bring the toolbar back without shutting down and restarting VM and does anyone know why it would disappear in the first place. Any help is appreciate. Thanks Dale Quote Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 10, 2019 What happens when you click on that little blue arrow? Quote Share this post Link to post Share on other sites
ShaneGreen 131 Posted September 10, 2019 That's a "context sensitive toolbar" so it's content changes depending on what you are doing. Does it disappear and the work area moves up into it's place or does it just turn gray or does it go black? It will turn gray/tan when you are using a tool like the node-editor that doesn't have any extra settings until a node is clicked. Once you click on some part of a design the node-editor has something to work with and the toolbar populates with usable tools. I occasionally have the entire upper set of toolbars turn black when I have too many large tabs open. The only way to get it back is to close down a few files. 1 Quote Share this post Link to post Share on other sites
diver4 1 Posted September 10, 2019 6 hours ago, slice&dice said: What happens when you click on that little blue arrow? When it disappears the blue arrow is not there. Quote Share this post Link to post Share on other sites
diver4 1 Posted September 10, 2019 3 hours ago, ShaneGreen said: That's a "context sensitive toolbar" so it's content changes depending on what you are doing. Does it disappear and the work area moves up into it's place or does it just turn gray or does it go black? It will turn gray/tan when you are using a tool like the node-editor that doesn't have any extra settings until a node is clicked. Once you click on some part of a design the node-editor has something to work with and the toolbar populates with usable tools. I occasionally have the entire upper set of toolbars turn black when I have too many large tabs open. The only way to get it back is to close down a few files. The toolbar just disappears, there is space where it was on the screen but it is not there and the only way I have found to get it back is to restart VM. Of course it has not done it all day so I can get a screenshot of it... Quote Share this post Link to post Share on other sites
diver4 1 Posted September 12, 2019 Here is a screen shot when the toolbar disappears.. As you can see in the red box there is a space for it but I have found no way to bring it back other than shutting down and restarting VM... Quote Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 12, 2019 I sent a PM to Vinylmaster to see if they will answer - Quote Share this post Link to post Share on other sites
ShaneGreen 131 Posted September 12, 2019 Can you get a screen shot of the left-hand menu and then the bottom of your work area? That will tell what mode you are in, etc. It will make trouble shooting a whole lot easier. 1 Quote Share this post Link to post Share on other sites
diver4 1 Posted September 13, 2019 19 hours ago, ShaneGreen said: Can you get a screen shot of the left-hand menu and then the bottom of your work area? That will tell what mode you are in, etc. It will make trouble shooting a whole lot easier. Here is a full screen shot of it, this is while the toolbar is there, next time it disappears I will take another full screen shot... Quote Share this post Link to post Share on other sites
diver4 1 Posted September 13, 2019 21 hours ago, Dakotagrafx said: I sent a PM to Vinylmaster to see if they will answer - Thank you. Quote Share this post Link to post Share on other sites
Guest Jesse Posted May 26, 2020 Any resolve on this topic? Been having this issue for a while now. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 26, 2020 2 hours ago, Guest Jesse said: Any resolve on this topic? Been having this issue for a while now. Put a ticket in with Vinyl Master. They are your tech support. And be sure and tell them which version you are referring to. 1 Quote Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 26, 2020 4 hours ago, Guest Jesse said: Any resolve on this topic? Been having this issue for a while now. any word when you are opening back up for tourism?? how is everyone holding up down there? Quote Share this post Link to post Share on other sites
